F
Flange
Hi guys (and gals)
I hope you can help me. Will try to keep it fairly brief! :grin:
Have a Torrent ECO with woodburner downstairs, so gravity. All working well for the past year, apart from rads getting hot then cool (as the water gets pushed round the system) so instead of standing with my hand on the rad flow pipe to turn the heating off in order for the store to heat up again, I wanted a pipe stat to turn the pump on at temp (55 deg?). Also, I wanted the CH timeswitch moved downstairs.
Leccy man (a qualified friend in the area) duly moved Drayton Lifestyle downstairs (and immersion controls but that is separate and all fine), and wired in pipe stat. All seemed ok but tank not hot so not tested.
Later I had a bath using immersion and didn't want to waste a tankful of hot water so turned the heating from off to timed, and the fuse tripped.
Disconnected pipe stat and is not tripping anymore BUT the CH pump is now continually running (both valves are also vibrating) although the CH timeswitch is set to OFF.
I replaced the boiler overheat stat and still pump is ON.
So....
1. Can anyone see a glaring fault in my diagram (without pipe stat)?
2. Is this how it is supposed to be wired? (with pipe stat)?
Many thanks in advance.
nice drawing by the way ,and there is a but, get a some body in that can help you.
Ta! And thought someone might say that :disappointed:. I've had a bit of trouble finding someone to help, and grabbed my friend when he came down. Thermal stores seem to be avoided like the plague by electricians for some reason!
To clarify: my electrician friend is stumped (and a bit embarrassed). I have taken photos etc to send to him, as he doesn't live near me. I posted the drawn pics because I thought the photo would be unclear (and I'm a bit OCD about visual aids, lol). This is (or was!) an up and running system for my place in the sticks. And as I am lime plastering at the mo, it's a right pain not being able to have a bath! Even a clue would help at this stage! I'm practically pleading :praying:
The pipe stat drawing is mine, though. I think it was wired wrong before, as he followed the Torrent wiring plan but that pipe stat was meant to be placed on the return flow from the stove, if I'm not mistaken. I know it has to be wired in series from the programmer, and I think it's C + 2 to open at temp? It's still a secondary issue, though.
I think it was the front ring (my house is wired in quarters) when I switched the programmer from off to timed. The control panel is wired to a fused spur.
flange ,take all the tails out and start again ,start with wiring plan and start putting the tails one by one ,it could be no simpler .
Reactions: 123
Hi - ok, was it an RCD trip, an MCB trip or a fuse blow? Then which circuit is it on? Then does it happen twice (say).
Hi,a bit more of a description of the layout,would help. How is the gravity/pumped sections arranged? What other electrical items are on the same power circuit(s)?
It is perfectly possible,if it worked previously,that an individual component,has an issue. This would need tracing,using standard tactics.
Even when viewing cables,in a wiring junction box,is no use,if we don't know how and why they connect,at the other end;)
Just banking that they do...is fatal,in the fault finding job.
I am with PEG - need much better description and diagram of the plumbing system and how you want it to work and be controlled. Some pictures always help add clarity to explanations.
Gravity water from woodburner downstairs to thermal store upstairs. Pump on rads coming from store.
Fused spur supplying feed to control panel only upstairs.
Has my first post, with the diagrams, disappeared?
Have my wiring plan posts disappeared? I can still see them...
No, your wiring plans have not disappeared....
Oh, I see! Sorry. Here is a plan of my system (thank god for Paint, haha). Obviously it has immersions but they are separate and working fine. My system is very basic.
Update: I have found someone to have a look but they can't come out until next Friday. If I could have a bath before then, I'd be very happy!
  • Funny
Reactions: Flange
Hi bud,it was a diagram of your particular layout,i was after,not Gledhill's generic drawing. The operation,and therefore the possible issues,are specific to each system,on an individual basis.
The addition or omission of a loader,or gravity flap,pump,feed or vent,in the wrong place,may or may not cause an immediate problem,until the day another thing changes,then....
If your system worked fine until presently,and has only now started tripping out,it very well could be a fail of a single,electrical item. It could be that a situation has occurred in the system,where two components switch to a position they have not normally found themselves,and this has caused the problem.
If you have someone coming out,then hopefully you can get sorted and clean:) ....but if your system looks identical to that generic picture...i'll dress as Gladis Emmanuel and bed-bath you myself ;)
Thermal Store problems
Central Heating Systems
Flange,
PEG,
