pc1966
Supporter
Mar 6, 2020
9,971
12,559
18,688
Dundee
I have a Martindale VT12 voltage tester which is OK, but very quickly I discovered the continuity function is a right PITA. Test for volts on the neutral and it lights up and squeals at you!
Takes a moment to realise it is the continuity LED that has lit, and the squeal is slightly different from the "volts detected" squeal, and all you have found is that you have the expected N-E continuity, but with it detecting anything below 200k ohm even that is not telling you a lot.
So for me when I get another it will be volts-only, but what do folk here think?
John Drummond Voltage Indicator, for my tupenceworth.
you ***** dinosaur. :p :p :p. and before you throw your toys out, I have a drummond also. :) :) :)
  • Winner
Reactions: Pete999
I have a Fluke T5-1000 which is great
I have never liked them ones with light up rows of lights
Only One Tel? last count three for me
Why doesn't it look professional? As long as it proves the voltage why would you need an all singing all dancing waste of hard earned?
If you are proving live or not then use a Voltage indicator, if you are measuring the Volts AC or DC then use a Multi metre
[automerge]1584455947[/automerge]
No its not that, its because they do 'Ranges'. I find seeing what the voltage is on a display is much easier for fault finding in certain situations
Then use a Multi Metre a voltage indicator it is what it is an indicator nothing less. trouble is far to many newbies are sold instruments they don't really require see safe isolation best practice for further information. What would you use in the safe isolation procedure?
I agree they are fine for proving live or not but why carry an additional multi meter (Or MFT) if the T5 does both and also can measure current in its jaws too
Each to their own, I have used both types and that's what I prefer :)
I have and still use a Drummond tester for safe isolation, mine was £30 about 10 years ago and saved my bacon from being cooked numerous times!!
Reactions: Pete999
I remember getting my first JD VI, I checked it out and constructed my own ( out of interest only) JD the best by far VI in the trade along with the proving unit of course. these testers that profess to be self proving are prone to failure in my opinion, nothing beats the proper test kit.
[automerge]1584456522[/automerge]
Precisely. Well said that man
Reactions: SparkySy
You can't really go wrong with them they are simple and don't lie or go into self test when trying to prove things are dead.
Always keep mine close!
  • Winner
Reactions: Pete999 and pc1966
That is what I want - do one job and do it properly!
Reactions: SparkySy
You can pick them up for next to no money mine came with the proving unit as well for £30.
Saying that you can't really put a price on your own life!
Mostly I have used multimeters for electronics work and that is fine when you are not working on dangerous stuff. The problems I see with using a DMM are:
  1. Correctly set on AC volts and working, you live
  2. Not working (fused probes blown, etc) and no proving test, you die.
  3. Set on DC volts, AC looks near zero, you die
  4. Set to current, PFC way above meter capacity, you die [in flames]
  5. Set to current/ohms, fused probes per GS38 or PFC manageable, did not notice the "bang", you die [electric shock]
Already have proving unit, will look at getting a Drummond tester next. Any model in particular?
Mine is the MTL10 but all of them are good reliable solid testers!
my drummond is the cheapo version. a torch bulb in the handle with a neon in case the bulb is duff. i had a TS1000, didn't like it. current clamp readings 20% out and the ohms readings were a joke. sold it on. rely mainly on my fairy light fluke T3.also have a £25 chinese VI that has a LCD readout. each to his own, i say.
there nowt like a lolly pop stick with a light on it ,lol.
this is the one i bought as a back-up when i left my T3 at a customer's premises 40 miles away. still waiting for him topostit back to me.
I use a fluke t110 for voltage testing/safe isolation. Very good robust bit of kit.
I have the Martindale too but find that a bit flimsy for the everyday toolbar so it's in the reserve kit.
I also have a fluke t5 but that's not the tool for the job although a very good all round meter.
pc1966
Supporter
Dundee
Recommended voltage tester?
Electrical Tools and Products
pc1966,
Andy78,
