Dartlec
1,752
2,506
3,688
Kent
Business Name
Dartlec
First try using the new Click Mode switches today, and I love the way that every light switch is automatically a grid switch. That means you can buy a light switch and change the modules to whatever you like.
I was fitting an outside light and was able to swap out one of the switches on a two gang off the shelf switch, to a DP and normal switch to fully isolate, switch to auto or override. All for £4.20! They feel pretty good quality too, though time will tell I guess.
The fused grid modules look nice too - that and a switch would be way better than putting in a FCU where a light feed is running off a nearby socket.
I've mostly avoided grid switches before because of the extra cost, and the additional hassle with fronts etc, but at these prices I definitely think I'll be using these more often.
Anyone had any problems with them?
Have click switches not been like that for years? have they changed the design recently? I love their metalclad range, the sockets etc. easily accommodate 3 4.0mm2 conductors and the knockouts are positioned correctly inline with spacer bar saddles. They also sell metalclad euro module frames which is nice.
lve 'em to bits.
Reactions: Scolmore
Possibly, maybe it's just because they are now in Toolstation that I've noticed them. Their plain white sockets do seem nice too - though I must admit I like the colour coded terminals of the BG ones.
I didn't recall seeing their grid switches available before at any of the local stockists/wholesalers though. MK usually ended up as the easiest to get, but always found them fiddly and short on space, especially with dimmer modules.
Reactions: Scolmore
I’ve just moved to them from BG cheapos A little more expensive but much more user friendly.Also the poxy layout of the BG FCUs drives me nuts.
Reactions: Dartlec
I've always assumed FCUs are deliberately designed to cause maximum installation difficulty (MKs are maybe the exception). Not tried the Click ones yet but may have to next time I need one.
Hager fcu's are well laid out too.
  • Informative
Reactions: Dartlec and ruston
Thank you for your feedback! We're glad you like our MiniGrid switches! If you'd like to find out more on the range, you can visit: SCOLMORE GROUP | Manufacturer & distributor of electrical Wiring accessories & Lighting - https://www.scolmore.com/products/minigrid/
Our product is available in a large number of wholesalers throughout the UK, but if you ever struggle to find them please don't hesitate to let us know so we can have a look into it!
  • Informative
Reactions: Dartlec
Dartlec
Kent
Business Name
Dartlec
Click mode switches and new grid system are great
UK
Dartlec,
Scolmore,
