gazdkw82
1,913
884
688
leicester
Just finished installing a new staircase from 1st floor to loft. I would like to add some feature lighting on both the existing (ground floor to 1st floor) and new (1st floor to loft). I am after a really subtle lighting idea that is only just noticeable, I'm not keen on disco style lighting shoehorned in....
Any ideas?
Reactions: DPG and pc1966
What ever you decide, make sure you can access the back of the stairs or where ever you install lamps for maintenance. Got a client that has some nice lighting in the staircase, unfortunately it's stopped working and thus far we've been unable to find the supply or drivers.
Looks a nice bit of woodwork there.
Reactions: Dave OCD and DPG
Good point. It is a must to be able to maintain whatever it is I choose to install. The new staircase is easily moved at the moment so now is the time to install anything on the string or treads. The existing staircase is a little more tricky
I'm lucky to have a neighbour who is a fantastic carpenter. Gladly pay his day rate
Reactions: Dave OCD and pc1966
I've installed those when finished with my staircase. Have pir top and bottom. Quite neat and enough light at night
Thanks Kropaske. They are too prominent for me. Instead of sunlight source that's really obvious and almost the main feature, I'm looking for a light source that is hidden almost, the light output it more important than its point or origin.
i love seeing wood as it should be, not covered in some crappy paint.
I guess it depends on what else is there, but how about those hidden up-lights in cornice / coving?
Not seen those before. Do you have an example?
It is not something I have used myself, but this is the idea:
Would very much depend on available clearance, etc, around the top of the stairs.
gazdkw82
leicester
Staircase lighting
Lighting Forum
Tags Tags
lighting
gazdkw82,
pc1966,
