Discuss I need help with an electric shower wire which is too short in the UK Electrical Forum area at ElectriciansForums.net
Umarhafiz
We had our bathroom renovated about 10 years ago and the original builder had left the shower wire too short and i didnt bother to get it fixed right away as we had another shower in the new loft extension done by the same builder around the same time. A few years go by and i then decided to ask someone to have a look and suprisingly no one had a simple answer i dont know if the electricians in my area are no good or it genuinely is a difficult or risky thing to do. to this day i have not found anyone who wants to do it so i have come here to get a better idea of what i could do or what is the best option. The bathroom has been tiled and there is a bath tub under where the shower is meant to be. Sorry if ive not given enough information im not very clued up when it comes to bathroom wiring or any wiring really.
I think we need some more information here - what type of cable, where is it and how short is short?!
Some pics might help if you can post some.
The best option is to replace the cable for a longer one from the shower isolator to the shower. This would possible mean removing tiles to get to the shower. But as the cable is too short to reach the shower now then it looks like tiles will have to be removed anyhow.
Is the shower fitted now?
What size shower?
What is on the other side of the wall where the shower is (or to be fitted)
What size shower?
There is of course the possibility that the existing cable wasn't clipped inside it's short run inside a stud wall - in which case with a huge amount of luck and patience you can sometimes use the old one as a draw to pull in a new one.
What size shower?
Shower has not been fitted and behind where the shower is meant to go is the outside of the house.
one way or another it can be sorted, but a site visit would be needed to ascertain the best way without dynamite excessive disruption. i could manage that, but it's right on the edge of my travelling distance.
looks to be an easy job to be honest! Chisel out some more of the block around the cable for access, three crimp n shrinks and job done.
you would need 6.0mm insulated crimps (yellow ones). but they would need to be securely crimped as they will be carrying c. 40A, so must be as tight as a duck's arse. (I'm assuming 6mm cable from your pics ).
The “shrink” part of crimp n shrink is heat shrink sleeving.
it goes around the crimped cables, and when heated will shrink and pull tight against cable and crimps, just for added safety. Much more robust than insulating tape.
it is a simple job for someone with the right tools. As mentioned, you could have 40A running through it, and you don’t want to be in the shower when that joint suddenly fails.
Ok that makes sense thank you
You would also need to put some decent heatshrink around all the joints and both cables.
You also need to consider if It might actually be cheaper to get someone in to do it as you'd need:
-a short section of 10mm T+E (and probably have to buy more than you want)
-2 x 10mm crimps
-1 x insulated 4mm crimp
Heat shrinking in various sizes
6mm earth sleeving
+ Crimping tool if you don't have one
It all adds up!
-2 x 10mm crimps
6mm earth sleeving
It all adds up!
Yh i was thinking that as i also wouldnt know if ive crimped it properly and stuff like that anyone know how much i should be paying for a job like this?
If you have space to put it in, and it is definitely away from any water, but you have some means of accessing it for any maintenance, then something like this junction box is a better bet:
If it were me and I could somehow get the cable in the roof space above it, then using something like that and a longer run of new wire down to the shower would be easier.
You will get a variety of opinions on this!
Mine is that if you can find someone very local who doesn't charge more for 1st hour because it's local, it's less than an hours work to just extend the cable. £45 -£70 bracket.
Would it be an idea to fit the shower unit higher?
It might be simpler extending the water pipe up, than the cable down.
I wondered that earlier too. A John Guest coupler and away you go...
You’ll just need to chisel away enough brick away to get a push fit coupler over the pipe.
Don’t let any chips of brick enter the end of the pipe.
I was thinking what about cutting out the black plastic just below where the wires need to be inserted?
I was just about to suggest that. It doesn’t affect the ip rating of the shower, the physical strength or a fixing hole.
It might though, cause an issue with any warranty claim in the future as it may be seen as unauthorised modification.
Oh i dont care about warranty and i dont think it is still even under warranty as ive had the shower in storage for 10 years ?
I agree with @littlespark. The shower will be about 45mm lower than the photo by the time the elbow is rotated and in place. If you trim a little plastic away on the left hand side I reckon you'll be ok.
If you are very close, you could consider putting 10mm bootlace long barrel ferules on the end which will give you an extra cm.
Lads thanks so much for all your help. I think cutting the plastic away will work i will update you on progress as i am trying to find my angle grinder to cut a chanel for the wire wish me luck
Reply to I need help with an electric shower wire which is too short in the UK Electrical Forum area at ElectriciansForums.net
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
Hi all , I know that you are allowed to do like for like in your own home Ie change a wall light etc. I have an issue with one double plug thats...
