Mar 13, 2019
1,816
3,289
7,788
Warwickshire
Can anyone recommend a downlight that is suitable for installation in a flammable ceiling?
My client would like one fitted in a UPVC clad porch ceiling, and the downlights I usually fit (Aurora EFD Pro's) aren't suitable for this. Struggling to find easily accessible manufacturer's info on this.
most integrated units will comply as a numpty can't retrofit with halogens.
This is what I figured, many of them being of plastic construction anyway. Still, really hard to find manufacturers' info on this.
Thanks Tel
The "fire rated " means they reinstate the fire barrier after drilling the hole
Isn't it the F mark in the triangle that means they're suitable for mounting on a flammable surface ?
So those are fire rated and also carry the F mark according to the spec
These on Screwfix are fire rated but the q+a says not suitable for flammable surface
Reactions: Pretty Mouth
In no way is the cladding flammable but it may be combustible. The chances of a downlight generating sufficient heat that the material releases gasses which is the combustible component of the product is extremely low. Modern cladding is manufactured so it doesn't promote the spread of fire.
Thanks. I don't think fire rated is necessary in this instance, but a nice-to-have. Surprised that that one has the F mark, it is GU10 so halogens could be used in it, which I assumed would be a problem
Pardon my ignorance, but what is the difference? The internet dictionary definitions I have looked at seem to used the words interchangeably.
Flammables ignite at lower temps seems to be the difference
According to Google anyhow
Funnily enough i remember testing that pvc type cladding myself for flammability
I can't remember the exact context but was a work related experiment
I do a lot of fire risk assessments and the difference is important. An easy way to see is petrol and diesel, people would assume they are both flammable but only petrol can be described as such. Petrol in its liquid state will not burn it is not possible it is the vapour which burns vapour which is readily given off at most temperatures hence it is flammable. Diesel is combustible as it needs to be produced for want of a better word for it to vaporize in other words it must be heated, throw a match a diesel nothing happens but throw a match at petrol and the vapours will ignite.
Chip pan fires are a good example of a combustible source, the oil once at sufficient temperature will vaporize from the pan to the naked gas flame. Liquids do not burn as there is an absence of oxygen, one of the elements required for ignition it is only once vaporization takes place and it mixes with oxygen you can get a fire. Fuel, heat and oxygen remove any one of these and the fire is extinguished and this is the principle of fire suppression.
Solids such as plastic and wood are all combustible because a process must first take place to release the gases.
Just saying, I put a bunch of these in recently, due to the low profile. They are very nice, imho.
Thanks for this very detailed reply @westward10 . There is still a question mark hovering in my mind though - what, in the context of fitting downlights, would be considered a flammable material? Would this be polystyrene ceiling tiles for example?
Again they are combustible. I think when it comes to building materials flammable is not going to be an issue they would just not be used.
Now I'm even more confused. So when a downlight has the 'F' symbol with a cross through it, it actually means it shouldn't be installed in a combustible material (as opposed to flammable)?
Looks that way to me
"Carrying an 'F' mark, this fitting can be mounted onto a normally flammable surface, which includes standard building materials such as plasterboard, masonry and wood. Easily flammable surfaces such as polystyrene are incompatible."
Seems according to the description and the above discussion that F means suitable for combustible .but not flammable ie: polystyrene
Makes sense. Thanks @Mikegh
Warwickshire
Downlights for flammable surfaces
Pretty Mouth,
Pretty Mouth,
