- Dec 23, 2021
- 4
- 0
- 31
- United Kingdom
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
TN-C-S supply, shocks/tingles from earthed sink.
Latest NICEIC test (2017) from landlord shows 200Mohm resistance between E and N
As above, do I have a floating neutral, is this causing a leak from N, via bonding on sink to true earth (solid kitchen floor)?
