W
WarwickApp
Hi guys. Just wondering what everybody is charging these days for a board change? I've got a customer who wants theirs changed, all of it apart from the lighting is already rcd protected so hopefully no nasty surprises.
I'm going to install a split load RCD board (probably Fusebox if supplier has them in) with 8 circuits, nothing unusual, shower, cooker, couple of ring mains, immersion and a couple of lighting circuits.
I'll be providing all materials and labour.
I will do a full eicr afterwards.
Only a local job, a lovely chap who I've done a few jobs for so I don't want to by any means rip him off.
I had in mind £400 but a mate of mine has told me I'm too cheap. Let me know what you think guys. Cheers.
This just screams out "borrowed neutral" to me 🤣🤣
Apart from the immersion, it could be a 16th edition install.
But if it was wired in 60's or 70's the borrowed neutral is one to watch out for!
What's wrong with the existing board ? I'd do an EICR before I swapped it out, not afterwards... Also, I'd be fitting a full RCBO board with SPD.
I'm not totally opposed to dual rcd boards but I'd explain to the customer the value of an RCBO board, and see if they want to trump up the extra. I find that if you point out how many years the last one was in service, and how many years this new one will be, the extra cost over the lifetime of the new board is barely worth worrying about.
Do enough testing before to ensure you won't run into problems, especially IR tests!
As you'll have to do EIC and LABC notification anyway, the full EICR should in my mind be a separate work item afterwards with it's own price.
I charged around your price for a mates rates job, but not including the Lewden CU with SPD, 9 RCBO's, blanks, tails gland, flexi tails kit etc. So if you are throwing the materials in that is exceptionally reasonable. (My job in question was a one-off in Coventry so not far away)
Reactions: Jim_e_Jib
So that's why split boards used to be only half RCD protected....😀
  • Winner
Reactions: Dustydazzler
North of £680.00 otherwise bin the Job.
And Do all testing before to "get it all out in the open " Otherwise every man and his dog will think you have messed up when there is a issue
Is that £400 for Labour or including materials.
If its all in, how do you make any money, even then you're too cheap. Remember it's a fairly long day as you're still working at home finalising certificates
For a dual RCD board [Cost around £100 inclusive?] and for a very good and long term customer I'd probably say £450, but I'd also explain the benefits/advantages of an RCBO board with SPD and offer that for £600.
I would say for a split load as tel says £100 for a db.
Tails, henleys or an isolator and some earth £40
Test dependant on amount of circuits, if it's 10 @ £20 a circuit there is another £200
Then Labour a day at £280
Bit of office time to type up test £40
£660 all in for me or there abouts!
If your in Warwick add £100 on just cos it's Warwick 😄😄
Always full test before fitting new CU,or your 1 day to fit a board could turn into two days trying to stop it tripping...Also full rcbo board with spd cuts down on earth leakage problems tripping one whole side of a board
Reactions: SparkySy
Surely another £6 ? The CU of the Beast 🥵
Employed one spark, Taiwanese, I think.....great lad....s*** scared of travelling to work at one job....journeying on the A666 into town every morning.
Reactions: Dave OCD
I am in the process of getting mine done and the Electrician wanted to do an EICR before hand which is fine as remedials can be sorted out first so no surprises when the board is done.
I am going for all RCBO's.
These days, and especially if you only have 5-8 circuits or so, the cost difference for something like the Fusebox all-RCBO & SPD board is negligible compared to the skilled labour for installation & testing. But the reduction in possible future problems quite worthwhile.
Email
Time zone
Last seen
Cost to change a fuseboard.
WarwickApp,
pc1966,
