Feb 10, 2021
15
Essex
Hi all, I hope.you are well..?
I am hoping one of you super heroes can point me to the right supplier...
A customer of mine would like plaster in down lights and already has some in one room (done by another firm). The recessed bit of the baffle measures 50mm across (approx)...
Would anyone know where I can get something in a similar diameter (50mm). And fire rated and ip65 too 😬.
Many thanks in advance for any helpful guidance 👍
Have you tried your friendly search engine
Quick google search shows these...
That's not a plaster in downlight
I'm not sure I understand the point of plaster-in fitting rather than standard down lights.
If one fails, do you have to get the ceilng re-skimmed after replacing it?
Im assuming they are the type with replaceable lamps.
Essex
Plaster in down lights
SuseJC,
brianmoooore,
