M
MarkODon
Hi, just looking for a bit of help with a problem I have. I’ve done a bit of wiring to my apartment as we built an extension. The RCD (earth fault protection) is tripping when trying to use the sockets. The work isn’t finished and I just need power in one socket so the builders can use it.
When trying to solve this I’ve disconnected most of the other circuits and left it in a state that only one socket circuit is in use as that’s all that’s needed for now. But now it’s not working at all. This is how it’s been wired. All I’m showing is the main fuse, rcd, and mcb..
(all that’s still connected is the lighting circuits if needed I’ll disconnect them fully as well just really need this sorted ASAP)
Thanks in advance for any help.
What test equipment do you have as I suspect you may need professional help to solve this problem
Reactions: pc1966 and Petej999
The installation isn’t finished, I’m just looking to get one socket powered up at the moment. There will be a professional coming in at the end to do the testing with me. Is the wiring diagram correct do you know?
The diagram looks ok but I would still use test equipment to prove the RCD is functioning correctly and within specification once it's connected
Reactions: pc1966 and DPG
my guess is that you have the N in the wrong set of terminals.
or there's a fault on the socket circuit?
Is this a dual RCD consumer unit? If so, do have the neutral for the 'socket circuit' in the correct neutral bar?
Edit: beaten to it by telectrix
Given the fact you're in Ireland, I'm amazed your REC didn't insist on setting up the temporary supply. Isn't it an offence for anyone else to carry out this sort of work?
I could be wrong and perhaps @LastManOnline or @Risteard could clarify this point.
Reactions: pc1966
No Matter...... a 'professional' should be involved before use. It needs dead testing and live testing before use. It's a builders supply and should be installed as such, and tested fully.
Seems to me the rcd is doing it's job.
What if a building worker were to end up hurt?
Yes. I suspected this to be the problem at the start, but when I was disconnecting some of the other circuits I did a continuity check to make sure the neutral was on the right N bar
Reactions: Jim_e_Jib
Very true. Thanks 🙏
Troubleshooting on extension
MarkODon,
MarkODon,
