Aug 28, 2022
London
Trainee Electrician
Hi,
I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside.
The first dimmer switch controls the LEDs and the second is just a push on and off for the bathroom fan.
The current module for dimming the LEDs is a BG TRAILING EDGE DMTR. When this is down low it is still very bright and I would like them dimmed a lot more.
Can someone please advise of a better dimmer switch/module to enable the lights to be dimmer when all the way down.
J
First check the fittings are, in fact, dimmable LEDs….
I’ve fitted Varilight v-pro dimmer switches without a problem, but even dimmable LEDs aren’t always compatible with every switch, and vice versa.
Sometimes it’s down to trial and error to get a good combination.
Reactions: Jay92191
Check with JCC to see what they recommend, although as post #2 V-pro better than most once you get the hang of their programming!
Reactions: Jay92191
As above. I always fit varilight v pro dimmer switches. These can be programmed (fairly easily) to bring the brightness down as low as you want.
Reactions: Jay92191
Yet another reason to use cans rather than integrated LED. With GU10 cans you could fit lower wattage lamps.
V Pro all day long..................
Reactions: Jay92191
Hi. This are GU10 cans and not intergrated
London
Trainee Electrician
LED dimmer switch. JCC downlights too bright.
Jay92191,
Jay92191,
