davidc123
Hi
I'm having some work done at my house and the electrician has said we need a full rewire. I'm a bit surprised given that we passed an inspection 2 years ago and it raised no issues at all. We've just been told that the wiring is illegal and needs changing. Maybe i'm not understanding the point of the inspection certificate, but how is it possible for the inspection to raise no issues and yet it actually needs a full rewire? I've attached a page from the report, if it helps.
Also, I'm being charged £17k + VAT for a 4 bed house, which seems high to me. Is it?
TL;DR
Passed inspection with no issues but another electrician says i need a full rewire
There is no such thing a "illegal wiring". It maybe unsafe to varying degrees, but that is a somewhat different matter.
Have you go the rest of the test report (names/addresses redacted before posting)?
Can you provide some photos of the current installation, for example, around the fusebox?
To me this smells very fishy. First I would be asking the electrician for a written report on what points are failing inspection and the relevant regulations behind them (as is normal for a detailed EICR).
Thanks, i thought the illegal wiring comment was nonsense. I've attached other pages from the report and a photo of the fusebox
I'm not actually sure he looked at the fusebox though. He was more concerned about the wiring in the rest of the house, which had the older red/black colours
'Illegal' Wiring
Reaction GIF
Very curious about this one!
Do you have a page of the report that lists C1, C2, C3 and FI codes for the circuits?
It's not a Report. It's merely a certificate for replacement of the DB only, so the OP appears to be misunderstanding what it is stating. It relates only to the work carried out and does not declare that the installation is fine.
That's an EIC for a consumer unit change rather than an EICR
Ah OK, that's where the misunderstanding is. Thanks for the help.
On the other point, is 17k+vat a reasonable cost for a 4 bed house? We're having a new kitchen / diner, utility room and play room fitted too, so new points as well as a rewire of the house
Depends on the property, the spec of what you want, your location, whether it's occupied or not.
I'd get another quote though rather than rely solely on the electrician(s) that have said your wiring is illegal.
Sounds reasonable to me but then it would if I could get that price for a rewire. Check insurance and scheme membership before employing any electrician. In the South West where I am a four bed house with decent re-wire spec....6-8k is ball park. London 10-12k up North 2k.
Reactions: pc1966
First things First does the old wiring really new Re-Wiring
If its all needs re-wiring for example is old imperial cable or no cpc on lighting then £17K for a re-wire and new wiring of extension seems reasonable to me
But a job of this scope I would get ATLEAST 3 quotes maybe even 4 quotes
As suggested some pictures of the CU area would be good, to get a gauge of the age of the installation etc.
IMO pvc cable twin & earth is bullet proof in general.
I wonder if this person quoting in under the impression that the older red/black wiring is in some way unacceptable ? If so I'm afraid you're dealing with an idiot.
Come on Dave we all know red and black wiring is illegal in todays society
Me too! Or where i simply want to disguise my interventions!
Still got plenty red/black drums of cable in my garage...
and some twin red...
always handy to have
Red and black is pre 2007, unless you’re Dusty….
Not a valid reason for a rewire, there’s 50 year old red and black in perfectly good condition.
If there was a serious issue at the time of the CU change, it would have been documented at the time or fixed…..
The current electrician is trying it on in my opinion…. But of course, we’re not there, so we don’t know what’s he’s seen.
Has this electrician actually provided you with a report telling you why the installation is unsatisfactory?
Why do i need a rewire when i've passed inspection with no issues?
davidc123,
Acca dacca,
