- Reaction score
- 5,607
I need to replace a Hagar RCD (model number CN284U). This is a type AC RCD and I wish to replace it with a type A.
The model number for the Type A equivalent is CNA584U.
They are both 100mA, 100A, S type.
The only difference being is that the Type A RCD is referred to as 1P + N rather than double pole. I'm getting a bit confused by the difference?
I thought the +N meant that the N is just switched off when there is a fault but doesn't actually detect the fault itself.
What is the difference between a double pole RCD and a 1P + N RCD? With both types of RCD the phase and neutral become open if a fault is detected, so it must relate to where the fault is detected (i.e phase or neutral). Or.. it is just different terminology meaning the same thing?
