- Aug 12, 2017
- 14,337
- 20,736
- 3,557,381
- 51
- United Kingdom
Local funeral place is getting a new mortuary fridge unit, and needs some work done.
The CU, just for the room, is high up in the corner, just above the fridge unit. Stupid place to have it, as you need to crawl over the top of the unit to get to it. 2 foot of crawl space, and my dodgy knee. Great.
Board just needs moved along the wall to above the door, everything in surface pvc trunking on wet wall panelling. No trouble extending circuits.
No room elsewhere to put it. Walls are lined with cabinets and other equipment. Above the door is an improvement, just not an ideal working height.
From what I can see, it’s an old Merlin Gerin board, no rcd.
Ideally, would change the board to all RCBO… but I can’t even tell how many circuits are off this board.
Going in on Saturday to PAT their equipment… so I’ll get up on the fridge for a better look.
