E
Electricalserv
Went to a job today. Upon opening cupboard to service head. I am faced with what can only be described as a cast iron service head. Never seen one like this before!
Its of a large square shape with tails coming out the top. No sign of fuse. Disn't investigate if there was any way to open it.
My question is what the score with these can a board be changed or does the DNO need to upgrade it. Ze was 0.13ohms. It loos likle a tn-s
Anyone come across these?
got a pic?
:dizzy2:you have a 3 way choiuce.
1. call DNO out. 2. open the box and pull fuse. 3 . work with live tails.... option no.1. will probably cost... 2. will mean removing a seal . 3... dodgy. opion 1. is favorite. both 2 and 3 are naughty and might kill you. ....:shout:
If the lid 'fell open' then I'd only involve the DNO if there was a fused neutral (common on these heads).
Without opening the box I don't know what the main fuses are and as IQ has just told me these tend to have a fuse for the neutral aswell! I've heard that twice now!
the box lid might fall off, but so might half the fuseholder when you look at it.
tell them there's a funny smell
Reactions: 2 people
These cut out heads were once quite common, and probably quite a few still around and in service. They will be well in excess of 60+ years old now, and as IQ noted, often were equipped with twin rewireable fuses, though many have been subsequently modified to incorporate an early cartridge fuse and a neutral link. Only way your gonna find out what you have in your mystery box, is to open it up and have a look see!!!
To be honest, these heads should be replaced by the DNO without any questions asked, they are well past there useful life expectancy!!! ...Let's face it the DNO's have had there moneys worth out of them, ...several times over in standing charges over the years!! Right??? ...lol!!!
Reactions: 4 people
twin fuse in the one in the pic above
HI This is the same type I have in my house, the cast iron box has been opened in my house I was planning to use this as my NIC assessment but Im now thinking there must be a better option as I cant afford to fail. The system has been upgraded to a certain extent. But its just hard to figure out where to start lol I can take a picture of mine if you like
Yes!!!! Please
Reactions: 2 people
as per my previous post CALL DNO as opening these can open a box of worms an may lead to more danger DNO should replace it Specialy if you take Teelxtrikals advice and "Smell something funny"
Another point on these is the earths Iv seen are usualy soldered ,braised on the lead cover of the cable and in some instances they have "Allround band" type stuff on them so its realy a DNO Issue specialy as its before the meter
S
Cast Iron Service head???
Australia
Electricalserv,
nikmet,
