dontknowitall
I do not wish to become an electrician!!! Nor do i want to be an apprentice. I'm a plumber and happy with that!!!
I've had a trawl through some threads and looked on a few training websites but can't really find what I'm looking for. I'd be grateful for some ideas please!
My wife and I are thinking of buying a small house to renovate. Between us we can do plumbing, flooring, dry lining, plastering, carpentry, tiling, decorating, curtain making, etc, etc. (We can't/won't do building work on the structure or drains and stuff like that - just internal work.)
I passed the Part P Defined Scope about three years ago but have forgotten most of it as I've used my electrician when required during my plumbing jobs (anything to do with the consumer unit or installing new cables, switches, etc.) (I can wire and diagnose/fix faults on S-Plan and Y-Plan systems.)
However, despite the above I'm looking for a short electrician's course to learn and re-learn about wiring, first fix, replacing the consumer unit, the boring earth bonding stuff (I have a mega meter but forgotten how to use it) and so on. I believe that the LABC can test and sign off work or if not I think my electrician will probably be happy to test and do this for me.
Which course would you recommend? Any answers gratefully received!
Why would he bother using a spark? He says he doesnt wanna be a spark, he just wants to learn how to do it quick and get his spark to check it. Its so simple in it?
Upvote 0
I hope none of you lot want to ask a plumbing question.
We're much more friendly and helpful over there. I think I'll ask there instead.
Many thanks for taking the time to reply to my request even if don't know enough to be able to answer the question.
Upvote 0
You could always redo the training you've done which would probably cost about £800 per wek. Plus see if you can get some hands on experience with your sparky mate. There is no substitute for on the job experience!
Upvote 0
I would have re-done that course but the company doesn't function anymore.
It could be that I work with the sparky but I want to learn more about the theory beforehand.
Many thanks for the suggestion. MUCH more helpful than the others!!
Upvote 0
Thank you Supasparxs.
I know the hard part is the installation but without some theory it's even harder. Not TOO difficult to put a wire in (obviously depending on the circumstances) but which size wire, what type, etc? This is why I want to learn some theory.
There are loads of companies offering training and there are loads of courses - I don't know which course will be the most useful.
I'm not interested in the qualifications part, or becoming an electrician. I just want to learn how to do some of the basics. Which course (and possibly which company)? (West Midlands).
Upvote 0
Having re-read you OP I do wonder what you're up to. We sparks can be a suspicious lot!!
For example learning how to replace CU's and doing the necessary tests, certificates and notification is not something you can learn by reading books - you need to do them regularly.
Upvote 0
I dont know why we bother having sparkys. After all we could just learn some theory, get the job done and then have someone else test it for us then we wouldnt have to pay anyone to do the job. And we would save loads and not get a rouge trader that isnt qualified to do the installation......oh wait a minute.....
Upvote 0
I don't know why we bother having motor mechanics. After all, we could just tinker on our cars ourselves, get the job done and then have someone else test it for us. Then we wouldn't have to pay anyone to do the job. And we would save loads and not a get rouge mechanic that isn't qualified to do ... I'm losing you here.
Upvote 0
Tinkering with electrics in the home is dangerous. In fact it has and will continue to cause death because of people mistakes. If we get a professional in to do a professional job the risk is reduced to almost zero. Maybe I am mis-understanding your need for learning this but it seems you want to do the electrics and have someone else test it. I am not sure any professional will want his name on work that someone has done after going on a course to learn a bit of theory behind it. Still follow?
Why not just pay a professional and get a good job?
Upvote 0
I'd first suggest asking your electrician IF he would be happy to test it for you, I can guess his answer would be negative!
Seriously, he's not allowed to sign off on work that someone else (a non employee if he's a qualified supervisor) has done as part of his Part P scheme membership. So even if you did the course and subsequently the work on the house, you'd still have to add around £150 to the top of that bill to notify building control. By the time you've paid for a course and the LABC fee, you could have had the job done by your spark I suspect. If you put a lot of work his way, he may do you a "mates rates" deal (worth asking).
Upvote 0
Have to agree i am afraid. Electrics is no longer a DIY thing. It's great you have all those skills. I never will have all of them, that's for sure. However you are a plumber if i read that right. Are you a Gas Engineer too? If not i bet you are aware of the dangers... Electricity is the same and majo jobs such as re-wires and cu changes require a LOT of training, not a short course.
If you want to do electrics in your home... You may aswell do the c&g 2357 course. Or don't do it.
A "part p" course will not give you enough.
I hope that isn't too unfriendly for you but we on here have been concerned for far too long about people doing quick courses in order to do some electrics. It is then that shorts or bad habits or mistakes can happen and then death is all too common an outcome. :(
Sent from my Samsung Galaxy S II via Tapatalk
Upvote 0
I wouldn't expect my electrician to come and test my work on the basis that I'd put in all the wiring and then ask him to come round and test it. That is unfair and could put his livelihood at risk. I was thinking much more about the LABC route (we are going to be doing more than one house.)
The question still stands: Which course?
Upvote 0
Mr.Si
Thank you!!! Hugely!!! 2357. Or not, of course! :46:
Your post was not at all unfriendly and I have read it as you meant it to be read - advice given with good intention.
Being in the construction world, I know that electricity's dangerous and not a DIY thing. This is why I was asking how I could better myself.
Upvote 0
So the truth is out "we are going to be doing more than 1 house"
So if you're going to be doing houses up to make money why do you think that taking chances on the electrics is going to help you.
Thats a bit like ordering a £10K kitchen and then keeping the 1950's cabling and socket fronts.
Daft.
Now on a positive note why don't you work with a sparky, offer to do the back box bashing and help him/her with the cable pullling etc - that would save you money and get the job done correctly.
Upvote 0
Surely the fact that I want to improve myself and learn more shows that I'm not taking chances on the electrics?
I have not dismissed working with my electrician. In an earlier post I said: "It could be that I work with the sparky but I want to learn more about the theory beforehand."
What is wrong with trying to learn more? It's not all about saving money. Or is there a law saying we cannot learn?
Upvote 0
Which Electrical Course? I'm NOT going be an electrician
dontknowitall,
TPES,
Electrical Courses
