where can you buy those gold jib cards?
anyone can rewire a house but knowing how to do it is why people need sparks
and what does it mean by `partP passed`?
i nearly passed some reading through this...(involuntarily)...I passed some part Peee earlier on ,
i think the OP needs to take stock of any critisisms in here..and burn some midnight oil digesting BS7671...then applying it to the works he carries out....
I think the OP should just give up.
His customer must be off their head if they take this fool on to save £400!
I suspect this is a real possibility although it may have been said in jest.I reckon after all the headscratching and titting about time on this job, he will end up £400 out of pocket.
It sounds like you've quoted on a job the you don't fully understand the scope of works or any idea of how you're going to sign off or notify the work or how much this will cost.The only problem is I don’t know what the hell this sparks is quoting them for?!?!
I'm sure the homeowner is over the moon with your price but how on earth do you know if you'll even break even if you you don't understand the scope of works and you don't know your signing off/notifying costs?and found that I can do the job £400 cheaper and that’s still given me enough profit. They are happy and want me to proceed.
i`v already asked him this...I suspect this is a real possibility although it may have been said in jest.
It sounds like you haven't done any preliminary testing of the installation.
is this a true statement?
stick a blankety blank in....should be OK...i've not read every post, but the previous spark who quoted is 1 MCB short of a full board.
main earthing conductor to gas and water, FFS,MCBs dis. in 5 seconds. mein gott.
if it is, then i've got a load of certs to rewrite.
You will notice that the person who started this had gone quiet... If this person is for real, it's some what concerning that he has a jib card etc as his website states....
Screwfix was the last time I saw Mk boards on special , that was a while ago though, why not try BG ,,
