Discuss Main Earthing Conductor in the UK Electrical Forum area at ElectriciansForums.net
Hi,
Just want clarity on earthing conductor sizing. I know the table but wanted to know what people recommend about a earthing conductor within a PVC/PVC cable, is this earth big enough for the new board or run a separate earth at least half the Line conductor ( rule of thumb )
Hi,
I take it that you mean the tails to the CU. More info is required earthing arrangement ! What do you mean by rule of thumb.
Hi thanks for the response. I mean when someone sub feeds a board in PVC/PVC cable is the earth big enough. The rule of thumb is the earth must be at least half the Line conductor so PVC/PVC cables wouldn't meet it.
Reply to Main Earthing Conductor in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Morning All, Think I'm having a brain fart but I have a 70mm2 4 core SWA with a separate 35mm2 CPC. Earthing is TNS with main bonding...
