Discuss 11kv transformer and bonding to gate housing in the UK Electrical Forum area at ElectriciansForums.net
If you are taking about bonding the gate or fence surrounding the TX, then UKPN stipulate 70mm2.
You need to look at the earthing configuration between HV and LV. If they are combined at the TX, the surrounding coupled earth electrodes need to be below 1 ohm (before cables are connected) to limit the touch voltage being imported into the LV installation, in the event of a HV fault.
Reply to 11kv transformer and bonding to gate housing in the UK Electrical Forum area at ElectriciansForums.net
