Discuss 1mm Cable instead of 1.5mm? in the DIY Electrical Advice area at ElectriciansForums.net
Ghacking
Hi, I’m wiring up an outside light from a junction box and have realised I’ve brought 1mm cable and not 1.5mm. Really want to get it finished today, Can I still use it? Its powering an up and down light with 2 x 5watt led bulbs. Thanks in advance.
Graeme
Yes you can
[automerge]1586278589[/automerge]
Although it depends on where the junction box is supplied from. If it's a lighting circuit, the answer is a resounding yes. If it's not a lighting circuit, the answer may be a resounding no because the fuse/circuit breaker for the circuit may not protect the cable in the event of a fault.
Yes you can
It’s off a lighting circuit so perfect. Thank you!!!
Reply to 1mm Cable instead of 1.5mm? in the DIY Electrical Advice area at ElectriciansForums.net
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
