Search the forum,
Discuss Shower extractor fan off socket circuit in the UK Electrical Forum area at ElectriciansForums.net
impish15
Trainee
Hi
Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired into the socket circuit not the lighting circuit (I have never seen this set up before) and hasn’t been fused down. So because of the way the extractor fan has been wired spured off the ring socket with no switch/isolation the fan runs 24/7.
The option to resolve the issue with the fan constantly running and the fact it hasn’t been fused I was thinking of identifying the fed (from the living room next door assuming) to the extractor fan installing a new 3amp fused switch (next to the switch in the sitting room) for the fan. I would have attempted to connect the fan to the lighting circuit and add an isolator but the walls are tiled and this would cause a lot of damage.
Please let me know if I have missed something or a better way of doing this.
Thanks in advance
If I've understood right, another option might be a fan with a PIR on it, so it would continue to extract for a duration after a shower.
The Vent-Axia Svara fan might be a good choice. It has Light, Humidity Sensor & Overrun Timer and delayed start and can be App Controlled via smart phone or tablet.
Reply to Shower extractor fan off socket circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
