Discuss 220V outlet with on/off switch in the UK Electrical Forum area at ElectriciansForums.net
I want to install a 220V outlet in the garage. Unfortunately the breaker box is full but there’s a 220V outlet in the laundry room that is not being used.
Can I run the new outlet off the same breaker and put a switch in the circuit that would turn on the garage outlet and turn off the laundry room outlet and vice versa?
You didn’t mention the amperage but if that breaker is not being used yes you can use it but remember all garages and buildings have to be GFCI protected
The breaker is currently 30A but I might switch it to 40A, depending on what the yet to be aqcuired welder requires.
Is it allowed to put a 3 position changeover switch in and leave both garage and laundry room outlet hooked up?
If you are talking about a transfer switch the yes
Reply to 220V outlet with on/off switch in the UK Electrical Forum area at ElectriciansForums.net
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hey all - I’m trying to change out a switch only with a combo switch/outlet. After doing the wiring everything seemed to be working but I then...
