B
brucelee
please can someone advise,
couple of questions thats mixing me up
1. state the purpose of initial verification of a newly installed lighting circuit
exam success says
. to confirm the circuit complies with designers intentions
. the circuit has been designed, installed and tested with the requirmements of bs7671
. it is not damaged so as to impair safety or otherwise defective
the booklet college gave us says
. materials of the correct type to comply with BS
. Erected and selected properly
. no damage or defects are present
what do you reckon guys
2. state the purpose of a periodic inspection and test of an electrical installation as defined in bs7671
exam success says
. To establish wether the installation is in a safe condition for continued service
the booklet from college says
. safety of persons and livestock
. protection against fire
. no damage
. identify defects and non-compliances
which do you reckon is right to answer
last one
3.a) state in the correct sequence, the first three tests to be carried out on a new ring final circuit
exam success says
. continuity of protective conductors
. continuity of ring final circuits
. insulation resistance
or alternative
b). contniuity of ring final circuit conductors conductors
. earth fault loop impedence
but when tutor gave us sample tests same as exam success he wrote CE report says
c).continuity of ring final circuit conductors
. live polarity
couple of questions thats mixing me up1. state the purpose of initial verification of a newly installed lighting circuit
exam success says
exam success says
. no damage
last one
exam success says
or alternative
. live polarity
