Discuss 3 phase, 3 bed flat in the UK Electrical Forum area at ElectriciansForums.net
B
brewlab
Hello all,
I have been asked to fit out a couple of flats and I think they require a 3 phase supply, my friend thinks they will be OK on single phase. There will be no gas supply to the property.
3 bed flat will consist of......
3 x 9.5Kw Powerstream instant water heaters (2 bathrooms and a kitchen)
5 x 2Kw thermostatic panel heaters
1 x 500w bathroom heater
1 x 6.5Kw Hob
1 x Kitchen ring (oven powered by this circuit)
1 x ring for bedrooms and living room
And the usual lights (pendants only) and smokes
The two bed will be same apart from one less powerstream and 2 less panel heaters.
What do you fellas think?
I think i'd be asking someone to design a combi heating solution based on an electric boiler and compare it for viability against the cost of a three phase supply. Prospective energy bills included.
Without knowing your KVA allowance or supply size and/or the availability to upgrade the single if needed then we cannot really comment, as you have no 3ph loads as such then there is no real requirement for having a 3ph supply, the load balancing over phases will only benefit the DNO and will be subject to there network conditions.
I agree, but you haven't met the developer/landlord. He's very single minded and wants everything done as cheaply as possible, I don't think he is concerned with the bills the tenants will receive.
The DNO has not yet installed the supplies to the flats, I'm trying to get hold of a name and number from the developer/landlord so I can have a chat with them and ultimately try to arrange a meeting on site.
Reply to 3 phase, 3 bed flat in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
...2 x 22kW EV chargers, 10kW of solar panels + 15 kW batteries and a heat pump for a 4 bed house and a 1 bed detached garage office? Got 3 phase...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
