Discuss 40 amp range circuit. in the UK Electrical Forum area at ElectriciansForums.net
hifidan
I have an un-used 40 amp range circuit and I want to use it as a temporary 2X120 Volts 20 Amps circuits using a 3X12 gauge wire. I'll be using the wall range connector. Do I have to change the 40 A breaker to 2 one pole 20 amp breaker or can I keep the 40 amp 2 pole breaker. Thanks
Yes you have to add 2 twenty amp single pole breakers. Get rid of the 40 amp breaker
Reply to 40 amp range circuit. in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I need to add shop lights to my basement. I currently have one baseboard heater that runs straight to the breaker. Its a cadet 240v/4.2amp 1000w...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
New member and DIY. I have a 60 AMP breaker going to a sub panel for a workshop. Two months ago I bought an electric car and a 40 AMP charger...
