Discuss 555 timer and a servo motor. in the Australia area at ElectriciansForums.net
simmisj
Hi.
I am building a timer circuit to control a servo. I have an Acoms as-17 servo. I want to make the circuit turn the motor clockvise 90° and then counter-clockvise 90°. I have been trying to build the circuits but they all fail. They just make the servo make a little bit of sound but does not move at all.
Are ALL servos using the approxamatly 1ms to 2ms (1.5ms being the middle position)?
I can't seem to see what I am doing wrong.
Thanks in advance
Simmi
If the servo is making noise at the correct time then your 555 chip is probably working fine. I would guess it's a power problem - is the output voltage/amperage sufficient to run the servo?
To be honest mate this is an electricians forum not an electronics forum, you may be best asking elsewhere.....
Reply to 555 timer and a servo motor. in the Australia area at ElectriciansForums.net
Hello all. thanks for allowing me to join. I am a DIY'er, own/operate a sign fabrication shop (Webb Signworks) and am a skidsteer and tractor...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Hi All, Thankyou in advance for your help I have a block of 5 stories with a staircase timer already installed in a 3 wire connection setup. I...
We have this type of "mechanical" timer switch to control our central heating, which is Potterton combi boiler. The switch keeps failing after 2-3...
Hello I have an old timed extractor fan in the bathroom which has stopped working. It has 3 wires which are black, brown and grey. I believe that...
