K
Knobhead
A bit of socket / plug history, some of it plagurised from Wikki, some from memory, some from personal experience.
In 1941 Lord Reith, the then minister of Works and Planning, instigated the establishment of a series of committees to investigate and report on the problems likely to affect the peace time rebuilding of Britain. One of these, the Electrical Installations Committee, was charged with the study of all aspects of electrical installations in buildings. Convened in 1942, they reported in 1944.
One of the most far reaching recommendations, still in effect in the 21st century, was the introduction of the ring main, where, instead of each socket being individually wired, a cable was brought from the fuse or circuit breaker in the distribution board and wired in sequence to a number of sockets before being taken back to the distribution board and wired to the same fuse or circuit breaker. This provided considerable savings in the copper required to wire the circuit. Since the fuse or circuit breaker had to be rated for the maximum current the ring could carry 30A, it was required that the plugs used to connect to the ring each contained their own fuse rated for the appliance that it connected.
The plug and socket system defined in BS 1363 is a result of another of the report's recommendations. Britain had previously used a combination of 5 amp and 15 amp round pin sockets, where each had to be wired to the distribution board where it would be provided with its own fuse. In a supplementary report, published as an appendix to the main report (July 1944), the committee proposed a completely new socket outlet and fused plug should be adopted as the "all-purpose" domestic standard. A number of technical details were required of the new standard, first of which was that “To ensure the safety of young children it is of considerable importance that the contacts of the socket-outlet should be protected by shutters or other like means, or by the inherent design of the socket outlet.”
[SUP] [/SUP]This requirement for a new system of plugs and sockets led to the publishing in 1947 of "British Standard 1363 : 1947 Fused-Plugs and Shuttered Socket-Outlets
Off the beaten track
MK anti-flash socket (2-pin 5 and 15A versions) that has shutters covering the inserts as soon as the plug is withdrawn. This is marketed more as an arc-reduction device (they weren’t switched) than a safety shutter however.
Dorman Smith plugs and sockets. These were very common in council installations. The Dorman Smith system had an interlocked switch. Inserting a plug unlocked the switch, turning the switch on locked the earth pin in to the socket so it couldn’t be withdrawn. (I can remember the Dorman Smith system as a kid, my aunt’s house had them).
Wylex plugs and sockets had a tubular central pin with the flat N pin in line and the L offset. The fuse internal to the plug. The 15A plugs had a novel feature, you could put a 5A plug in to the top of it. (Who needs adaptors). One of the electricians I served my time with had these in his house, he wouldn’t change to the “new fangled” 13A sockets!
Bellmoss Pebbles didn’t take off for domestic use, but did in industry. The fuse was the live pin it’s self. Great if the pin snapped in the socket (as happened all to often). If you spent the few bob more you could have them switch interlocked like the Dorman Smith system. They were a pain in the a**e!
Reactions: 6 people
As far as i remember Tony, it was the Dorman Smith plug tops that had the fuse as the pin, We had them in my parents house until i rewired the place. You didn't mention that at that time, socket outlets were Besa box mounted in the whole, ....when recessed as in most domestic installations used a square over cover flat-plate. Same with the light switches they also fitted standard Besa boxes, and when flushed also used a square over cover flat plate...
Can't totally remember, but i don't think the switch was interlocked either. My parents house only had one switched outlet, in the kitchen, ...it was also the only socket in the kitchen. ...lol!! But all the rest were unswitched.
Can't say i ever heard of Bellmoss Pebbles in industry, maybe if i saw one it would jar the memory cells...lol!!
Reactions: 2 people
Why didn't I think of that
Interesting link
Is it my imagination or did they link live and neutral pins during manufacture
I especially liked the novel multi plug
Interesting link
I think there lays the problem with this particular innovative design, the movable conductive paths are too close together to allow any meaningful current to pass without heating up the insulating plastic, and melting it. Plus they looked too small to safely pass any meaningful current themselves.
Maybe fine for tiny load applications in it's present form, but not much more!!! But i do like the idea....
Reactions: 2 people
I’m impressed, but not that much.
It’s a bloody good idea, but fraught with danger.
Looking at it tony i cant see how they are going to achieve adiquate electrical seperation as there dont look to be much between conductors there. Also as mentioned earlier in this thread it dont look like it will have much current carrying capacity but if this type goes to production it would have to be restricted to low current using equipment wouldn`t it?.......
Great idea for mobile small current equipment. Companies such as iPad will use this plug so of course it will be moulded fittings both ends until some one cuts off the laptop connector and puts a hair dryer on it.
They look like the sort of things that bomb crews screwed into ordnance before loading the bombs into sterlings/lancasters on those old pathe news reels..lol........
I just wanted to say thanks to all of you who have contributed to this thread. I've found it very interesting & really enjoyed reading it. :)
Australia
Knobhead,
Geordie Spark,
