Discuss Adding a socket from a Fused spur in the The Welcome Forum area at ElectriciansForums.net
P
Pmetcalfe
I wanted to know if a radial circuit that has a fused spur at the end of the circuit can then feed a double socket if I use a 13amp fuse in the fused spur? Also would that then have enough power to run a washer and maybe a chimney hood fan above a cooker hob?
what , if anything, is the fused connection unit supplying at present?
it should be OK, load not exceeding cable capacity and fuse rating. RCD protection is, however, essential.
Okie dokie thanks will investigate more when I go and look at the job if there is no rcd protection I'm assuming it will just keep tripping once the socket installed is used if I was to do the install?
Could always fit an rcd fused spur feeding the socket.
Also rcd protection can be omitted with a socket feeding an item of equipment specifically labelled . It would not necessarily need rcd protecting providing cables aren't buried in walls < 50 from surface
Regulation 411.3.3 (a)
No rcd a washer and cooker hood?
What else is on the radial circuit. What size/type of cable is it wired in? As long as the total load on the circuit is bellow 20A and it is wired in a suitable cable, I see no reason why you can't continue the circuit to the 13A socket without going through the FCU.
If there is no RCD protection to the circuit, this will need to be added and the easiest way will probably be an RCD FCU.
It's in a kitchen so fridge freezer, kettle, toaster that kinda stuff and washer and chimney hood plugged into socket I would be installing fed from a rcd fused spur with a 13amp fuse would that then be acceptable and most importantly safe?
Pmetcalfe, in post #11 you stated that you would investigate whether the circuit was RCD covered and now you plan on RCD Fcu feeding the socket. You need to be careful on here that you tell it as it is. When there's blood in the water they can smell it!
If this is your dwelling, tell it as it is, be honest and the forum is willing to help. Read the books, take a look at appendix 15 in the BS7671 and acquaint yourself with fault protection requirements and additional protection. You'll need to do a lot of archive reading from the forum - use the search button and get immersed, that's where you will get your answers. All respect intended. Rob
Reply to Adding a socket from a Fused spur in the The Welcome Forum area at ElectriciansForums.net
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
