OP
Octopus
Yup. And even with one it's not easy. Trying to resolve one right now!
Discuss advice on changing my consumer unit please in the UK Electrical Forum area at ElectriciansForums.net
get the snips out, man. :bucktooth:Yup. And even with one it's not easy. Trying to resolve one right now!
Your 'well informed' advice was do not meddle with stuff you clearly know nothing about, like it or not it's not red tape it is the law. Is risking your own or your families life the cost of getting someone out who knows what they are doing, has the correct test equipment to find the fault, fix it and can put things right? You will probably spend more money doing work that doesn't actually need doing by having a go yourself. As and when you come to sell your house you will need a certificate for the new consumer unit and associated notifiable work.I was hoping on this forum to get some good informed advice rather than a reminder of the red tape we are currently under. If nobody dares to give me any advice then I will have to work it out for myself.
Thanks for the feedback people. I know what I need to do its just that I haven't found a piece of kit that will do it. Handysparks, the boards I have seen so far are typically split with RCD protection but don't have a spare slot for a single RCBO outside the control of the RCDs monitoring the split groups, so if you could point me to such a thing I would be grateful.
Also my point about the garden fault is surely that there is much more incidence of RCD trips in a garden environment (mowers, outdoor lights pond pumps etc.) that regardless of whether I have a fault now or not I would like any fault outside not to trip the house
I inherited the existing CU when I moved in. The main isolator is an RCD which is safe but inconvenient. I agree that supplying the outside directly from the CU is the best way but at the moment the garage and garden has an armoured cable underground from the inside kitchen wall behind the fitted cupboards. I would have to isolate that and run a new cable from the CU to the garage. Changing the main RCD to an MCB would involve pulling the sealed fuse anyway so I'm now thinking I'll just find the fault in the garden and leave everything else as it is.
How do you plan to fault find? Do you have an mft? And competence?
Reply to advice on changing my consumer unit please in the UK Electrical Forum area at ElectriciansForums.net
