Discuss Advice on wiring a lightbulb in the DIY Electrical Advice area at ElectriciansForums.net
bigvibes
Recently moved into a house and there are exposed wires (3 wires) for overhead lights. I just need simple lightbulbs put in, so I got lightbulb connectors (see picture). I have a couple of questions.
The 3 wires have this little attachment with two screws on them (see the picture - I took it off one of them already). The lightbulb connector also has a place with two little screws. Is it fine to just take off the two screws on the wire, insert the wire into the lightbulb connector and screw it down or do I need some kind of attachment?
The lightbulb connectors have no ground pin and the wires have a ground wire. Is it safe to not use the ground wire and just tape it off?
thanks!
The E27 lampholder looks to be a Class II item which does not require an earth.
I'm not familiar with Italian regulations, but (in the UK) the connections need to be enclosed, and not just taped over (which doesn't count as enclosing them). For example, in a Wago box (if you have those in Italy).
Reply to Advice on wiring a lightbulb in the DIY Electrical Advice area at ElectriciansForums.net
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
