Discuss Several Lightbulbs Have Dimmed and Gone Out on the Same Circuit Breaker! in the DIY Electrical Advice area at ElectriciansForums.net
Summary (TL;DR)
Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling light in my living room won't turn on at all. It will turn on, go dim for 1-10 seconds, and then shut off completely. There are a host of other electrical issues in the other rooms supplied by the same breaker.
Details
I'm an idiot. 🤡 For the longest time, I thought it was the lightbulbs or the fixtures. Maybe, it is. ¯\(ツ)/¯ Here are the details.
  • The single circuit breaker (15 amps) supplies power to 2 small bedrooms, a small bathroom, a mini-hallway, and a small living room. (I live in a very small house. 😃)
  • The house was built in about 1950. I don’t know when the main panel was replaced but we purchased our home about 15 years ago.
  • The circuit breakers in my home have rarely tripped. The last time was years ago.
  • PSE&G has been doing work in my neighborhood for the past few years. I would get emails stating that they had done work. But, the power in my home turns off periodically. Maybe, once every 1-3 months?
Living Room - MAJOR ISSUE!
  • The ceiling fixture contains 2 LED lightbulbs. I replaced it a few months ago, thinking the light fixture was the problem. A few weeks ago, the LED lightbulbs were already very dim after a few months.
  • Right now, the lights won’t remain on. I will turn it off and on. The light will momentarily turn on for 1-10 seconds, dim to a very low light, and then turn off completely.
Bathroom
  • LED lightbulbs dim relatively quickly in about a year or two and eventually go out.
  • The light switch has a night light that is constantly flickering. Occasionally, the lights won’t turn on. I have to turn it off and on a few times. This happens rarely though.
Bedroom 1.
  • One of the power outlets had an issue. Again, I can’t remember too many details because it was years ago. At the time, I tried to replace the outlet because it burned something out. I think I discovered that the wires were crossed. The white wire was actually “hot” and the white wire was “neutral”. That shocked me so I just covered the receptacle and it hasn’t been used since.
Bedroom 2.
  • In the past, while unplugging a phone charger, sparks would appear.
I hope I gave you enough details to figure this out!
💭 So, can anyone make an educated guess on what’s going on?
💭 Should I check the voltage and amp at an outlet with a multimeter?
💭 Is the circuit breaker supplying too much power to that part of the house?
💭 Should I replace the circuit breaker?
💭 What is the likelihood that the electricity company caused this?
Reply to Several Lightbulbs Have Dimmed and Gone Out on the Same Circuit Breaker! in the DIY Electrical Advice area at ElectriciansForums.net
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
