H
howell
Hi
I wonder if someone could please offer some advice regarding the replacement of a motor run capacitor on a band saw motor. The motor hums when switched on and the wheels only turn when they are turned by hand and I understand from a bit of research that this could be either the capacitor or a centrifugal switch.
I have sourced the exact capacitor, a LCR M/R 16uF, 440v, twin flex connection and am looking to disconnect the old one and install the new, however, I am unsure how to do this. The connection is shown in the picture below, the little plastic connectors house the ends of the live and neutral cables one of each which come from the capacitor. Is it just a case of cutting the brown and black wires below the plastic connectors - not sure what these are called and connecting new ones? if this is a job that should be done by a pro then I will leave well alone.
Many thanks, Dave
Many thanks, Dave
