Discuss aerial advice for block of flats. in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Got a block of 6 flats to do.
What is the standard set up for Aerials? Wire all points back to Center point, or take an aerial to each flat, and use a booster?
Tom
It depends what the client wants, but often satellite and terrestrial aerials are supplied to each outlet along a single coax cable using multiplexers.
You could always run the cables and get an aerial company to supply and install the hardware.
Is it a normal rig or is for sat aswell?
I would run a shotgun cable from the intake area to each TV point and 4 ct125 cables (for sat) and 1 normal coax (for terrestrial) and a 4 or 6mm Earth from intake area to the rig
Reply to aerial advice for block of flats. in the UK Electrical Forum area at ElectriciansForums.net
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
Hi everyone, I am new to the forum and wanting some advice regarding a tv aerial. I moved into my own flat and bought a tv, however when I...
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
Hi all, I hope you could share your experience and advice regarding supply 50 flats in 5 storey block of flats. We get 3 x 430A supply. What...
