Discuss AFDDs are a massive fraud in the UK Electrical Forum area at ElectriciansForums.net
From an on the ground engineering point of view how exactly do you fault find the cause of an AFDD tripping especially if it is a nuisance trip with no test equipment available to verify the operation of the unit, does an AFDD's ability to detect a fault degrade over time or if it detects a fault does that reduce it's future efficacy or do you just replace it, there seems to be so many unknowns and unanswered issues with this new piece of kit you have to wonder why the IET have jumped in feet first on this one
AFDD nuisance trip inquiries are a daily affair @ NEC chatrooms
All manner of conjecture are usually entertained.
There are 'testers' marketed by the same manufacturers of them , but simply looking for something parallel Vs series usually reveals the problem
That our system incorporates a neutral makes this all the more tedious
Our AFDD's state right in the manufactured instructions to remove them prior to any megging
Which over time mother nature may introduce.
So what we installed 20 yrs ago may 'test' as far as the unit's test button , but there is (as yet) no lockout feature UL mandated for our GFCI's , over 50% (their studies) confirmed
~S~
Sorry, mother nature may introduce what?
Some of your posts are confusing.
The land of the free and the brave, no more then?
We all know America is smoke and mirrors.
People who believe peace can be kept through violence, the constitution protected by violating it and the oath sworn to uphold it, people freed by being enslaved, helping others by pushing them back down, depriving information is the key to education, ect.
Yet somehow AFCIs should not be view with skepticism. :rolleyes:
(If its OK to ask from your practical experiences,
have you spotted any of the following )
Returning to false alarms .
a) Are any brands better than others .
Do location factors provide any clues
b) Are cities / situations more prone ie near TV
Taxi , radio ham ,airport radar ?
c) Problems near car workshops / industrial welding.
Does the age of the install influence things?
d) Sturdy but worn older sockets
e) New flimsy parts of certain brands
~S~
[quote/]
GE (good enough!)
I wouldn't know, i live way out
I really should post some of our wiring to answer this for you, but yes, yes & yes
~S~
Thanks for your last three posts Sisyphus, they were most informative. I'm sure we all learned a lot from the technical detail. They go well with the ropey YouTube videos posted by your friend previously.
When working in the security industry, Racal had a pir that a device could be plugged onto its test pins showing +/- noise/activity in its area of coverage.
No doubt this opportunity will be missed, but I see no reason why a similar set-up could not be introduced as an industry standard with AFDD's.
Whether a separate instrument (that works universally with all makes), or an output that would work with a simple multi-meter, would at least give sparky's half a chance of fault finding with these devices.
Reply to AFDDs are a massive fraud in the UK Electrical Forum area at ElectriciansForums.net
Page 337 cites UL testing, where arc resistance was found to be only 30 milliohms...
Iv been given the scenario: 6 circuit earth fault loop impedance values were recorded. Each circuit has type B cb. referring to the maximum...
8K
