Discuss Armoured cat5e ................. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Zdb
Can armoured cat5e cable be run in the same containment as power SWA?
Or can anyone recommend a cat5e cable that doesn't need segregation.
To be frank although I know different containment methods are proscribed by BS7671, I have seen cat cables lashed over flourescents CAT II fittings recessed in suspended ceilings all over offices and so on. No one has ever noticed or complained of degradation of signal. I sometimes harbour a rather sceptical view of the idea that signal will be affected but that is just me.
Reply to Armoured cat5e ................. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
Hi all. I am replacing some cat5e cable with cat6a shielded in a large building. I have noticed the cabinets are NOT earthed and the electrical...
Armoured cable or equivalent to go around garden border for on the ground flood lights everyone using any alternative to swa, will H07RN be OK or...
Hi, I need to run a duct from our garage, under the (gravel) drive to the house. Specifically this is for a monitoring sensor needed for our...
I'm in the process of installing Catenary Cables to support 2x SWA and 2x cat5e cables, over a distance of a small distance of 1.5m. The cable...
