Search the forum,
Discuss Bathroom Extractor Fan opinion... in the UK Electrical Forum area at ElectriciansForums.net
Do you mean MVHR Des? If so it does work a treat, but no loft access available for the landlord in this case. If you mean something else what is it please as am curious..
I presumed there was a attic after reading his comment below,I did have a dry air unit in mind which would be mounted in the attic
I have fitted many of these units over the years and have had good feedback in all cases
quote(Not aware of trades accessing the loft space but the council's contractors are inspected the roof at the end of the month).
If he has no attic there is a unit designed by the company I use for the fans specific for flats but I have never installed one myself
Nuaire | Flatmaster - http://www.nuaire.co.uk/our-products/catalogue/residential/positive-input-ventilation-piv/flatmaster/
In my experience (as a landlord) this seems likely to be a tenant-specific problem, drying clothes with insufficient ventilation etc. If you do fit a good quality extractor fan, that comes on automatically, the isolator needs to be locked as they will switch it off. I had one tenant who decided that he was not going to allow the fan to run on for 10 minutes, and as the isolator was locked, he simply unscrewed the fan housing and reset the timer to zero run-on...
The place was full of mould in 2 months.
My opinion is just wait til council inspection is over, then install in loft space...if it's truly communal. so what? The intrusion of a flange and some ducting is minimal, and probably will go un-noticed anyway. If the tenant is unhappy due to cost of electricity...get Big Pete in, to "explain" things clearly...
Reply to Bathroom Extractor Fan opinion... in the UK Electrical Forum area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
