M
Mickyboro
Hi all, This is my first post and was after some advice. I have a baumatic bt2710ss range cooker and for some time now only the top element is working when you switch it to fan oven with both top and bottom elements. So basically the fan still kicks in and the top element works. It takes ages to get upto temperature. With the oven you can switch it to bottom oven only (without fan). This I have also tried and it did not heat up at all. I have replaced the element and still no joy. Is there anyway of checking the element to make sure it works? I have checked the wiring at the back of the element and all connections seem ok. The spade connectors are a little greasy and oily but there is still continuity from the cabling going to the oven control switch. Any help would be appreciated as its doing my head in now and I can't get anyone to come and look, more to the point I'd rather sort it myself. Cheers Mick. |
