Hi, I have a Beko DHR73431W heat pump tumble dryer that isn't heating. I'm thinking its beyond economic repair as I think the compressor has gone, but any advice is welcome.
The NTC's in the door and on the compressor are all reading what I believe normal at around 12kohms at room temp. The compressor is reading funny though. There is no short to ground, but run-common is higher than start-common.
I'm getting 7ohm between start and common, 11ohm between run and common, and just over 17ohm between run and start, and nothing between any of the terminals and the refrigeration tubes. From what I have read, I'm expecting a lower value on run than start. The compressor body is getting warm when trying to run, but nothing beyond a few degrees difference between hot and cold side on the refrigerant, and the circulating air is just room temperature.
- TL;DR
- Heat pump tumble dryer not getting hot, or cold on the condenser.
