Discuss Bonding Missing in the UK Electrical Forum area at ElectriciansForums.net
Morning all. Just been to a domestic due to a problem on a ring. Found the issue no problem. But when I removed the cover of the CU I noticed a new supply had been wired in for the heating, however the CPC hadn't been terminated and was resting on the MET.
So having re terminated the CPC and tested the circuit I checked the bonding to find the main bond removed from the water supply. Now question is the boiler is a few weeks old. Would you expect a heating engineer to confirm bonding? Even if it is only a visual.
Reply to Bonding Missing in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
