Discuss Bonding in the Canada area at ElectriciansForums.net
C
cupra52
HI all
This is my first post, only registered yesterday so be kind.
I went and done an estimate the other day for some extra sockets in a kitchen (yes I am part p).
Found that there’s no main water or gas bonding (no gas at property yet). Told customer that it needed to be done before I can work, she said fine. So quoted for water bonding as well.
Now won the quote and she told me that she’s having a gas supply fitted and new combi boiler, pipe work and rads.
So, my question is...
Will the boiler fitter provide main bonding to the gas (he’s due to start before me) and also what about the water bonding, are they required to do that as part of their installation?
Just want to get an idea of what will be done or not done when I turn up.
Your thoughts will be appreciated.
Someone will give you an answer before Monday cupra!!!
Sorry I can't help.
Welcome to the site. Some good guys on here.
to be honest, people tend to do as little as possible, I don't think they will bond it, as their probably not compentent to work on a supply/consumer unit,so its up to the sparky to bond it. As it'll be your name on the cert, not theirs, not their problem i guess.
thanks for your replies, stop cock is in the kitchen at back of house, with c/u in hallway at front (but already quoted to do this). I presume that gas meter will be fitted at front, so no big deal to do that either, apart from a small charge. the main thing i was getting at was, do plumbers/heating engineers have to work to the same regs as us? IE. main bonding must be in place.
The plumber almost certainly will not take care of any main or supplementry bonding, so It's down to you.
If it were me I would just get on and do it find out where the gas meter is going and run a 10 mm earth cable to it.
Theres no harm in "looping" 1 bonding conductor from the gas to the water providing the conductor is not broken. In most cases its as easy to run 2 seperate conductors.
Hope this helps....
Reply to Bonding in the Canada area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
evening everyone . Quick question here I’ve recently took over a job that a friend of mine first fixed it’s a 3 bed semi house rewire. I don’t...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi I have a 1st fix domestic install on the go and need to leave a socket for other trades to use after me. There is no main bonding at the...
What are the regulations requirements on Earth bonding ? I am currently planning a 1st fix re wire I have the following setup Gas Meter...
