- Reaction score
- 67,272
so i get a dislike from some guy who's posted 48 times in 6 years. ask me if i'm bothered.could always change the landing light for a gas lamp.
Discuss Borrowed Neutral - Solutions in the UK Electrical Forum area at ElectriciansForums.net
How does having extra slots help?Why is it a sin ? Two conductors for a stair and landing light circuit in your scenario is ok if you don't have any more slots for MCBs, etc. You will also solve the BN issue.
MK... I'd rather have a root canal treatment without anesthesiaOnly once have i been asked to do the remedial work, in part because they were getting plasterer's in so the making good wasnt an issue.
Would normally put both on the same mcb/rcbo and include a sticker on the cu and note in the EIC.
On another job, I took out/disconnected the parts of circuit with the borrowed neutral and replaced with the MK echo wireless switching kit. looked quite nice and matched other mk accessories. the wireless receiver is on permanent live and the wireless switch can go anywhere to activate it.
Why are you bothered?so i get a dislike from some guy who's posted 48 times in 6 years. ask me if i'm bothered.
Maybe I didnt explain it too well, the MK echo range takes the live and neutral from which ever floor the light is on into a small receiver that then acts as the switch, the conventional switche replacements on walls are wireless so can go any where, given its usually the switches that take the borrowed conductor from the other floor upto the landing or vice versa then the wireless switch resolves the issue, you can disconnect the switch cabling and use the echo kit. it removes the link between floors and different lighting circuits. I first came across the wireless stuff when working on a repair job on a budget hotel a couple of years back that had been flooded from a burst pipe. them card readers for the light in hotels are quite often wireless aswell.[/QUOTE]You've lost me a bit with that one. A wireless neutral?
nope. just wondering why the dislike.Why are you bothered?
I suspect the dislike in itself doesn't bother you in the slightest, but the lack of an explanation really gets under your skin, otherwise you wouldn't have mentioned it.so i get a dislike from some guy who's posted 48 times in 6 years. ask me if i'm bothered.
Reply to Borrowed Neutral - Solutions in the UK Electrical Forum area at ElectriciansForums.net
