T
TPES
When you come to do work in a property either an addition or alteration to a circuit, what are you doing when you find either of these RCDS in the board? (BS4293 Current breaker & ELCB Voltage operated breaker)
I know there obsolete now so should be taken out of service, correct?
So would you tell the customer they should have a new consumer unit?, The old type of wylex board this was in had the netural bar just behind the MCB's which would stop me fitting an RCBO.. On the main switch side.. (for me to comply to regs)
So is the only option to change the CU ?
