Discuss Cable routes in the Canada area at ElectriciansForums.net
U
Unregistered
As a floor fitter I have cut through a number of live cables which have been located in door jambs and stair stringers. (domestic properties)
Are there not rules about where live cables can run?
Should the floor fitter foot the bill for the repair, or is the householder liable for damage/injury to the fitter?
Yes cables are to be located in "safe zones" as given in BS7671 but not all are, especialy if installed some years ago or by DIYers.
As for footing any bill for damage or injury, well you'll have to ask a leagal beagle, or negotiate with the householder.
Reply to Cable routes in the Canada area at ElectriciansForums.net
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
Hi all, quick question - I have to replace a lateral supply cable where the existing one runs through the ceiling of the basement flat and up...
Hi, this is a repost of the initial in diy as the only potential diy aspect is the prep ahead of a qualified person attending, this is hopefully...
