Discuss can i spur off a cooker with a d, socket in the Australia area at ElectriciansForums.net
could replace cooker switch with one incorporating a socket outlet ( circuit being capable of handing extra load ). best way is to come off ring final if you want aq double S/O
not good practice, IMO, i suppose you could fit a FCU, you have to check loading and whether the cable will take the extra load.
ok thanks for that. how about a spur off the cooker switch and then out of the spur to a double socket
:confused: Isn't that what you just asked?
Edit i type a reply and you are always in there first tel - you do speed typing lol
Reply to can i spur off a cooker with a d, socket in the Australia area at ElectriciansForums.net
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
