Discuss Can someone once and forall tell me what a capacitor does in an AC circuit?Thanks. in the UK Electrical Forum area at ElectriciansForums.net
Yes but can I use capacitors to increase voltage across motor windings?
Yes, but not in any sane way.
Usually a capacitor is used with a motor either to phase-shift the supply so a single phase can generate a "rotating" magnetic field, or as power factor correction so the motor plus capacitor is nearly resistive (i.e. PF close to 1)
So a capacitor is used to generate a rotating magnetic field in an electric motor, how?
The current through a capacitor is proportional to the rate of change of voltage across it (I=C.dv/dt). A capacitor in a series circuit can therefore be used to change the phase of the current in that circuit relative to the supply voltage. If you have two identical windings fed from a common AC supply, one with a capacitor in series and one without, the phase of the currents will be different (assuming the capacitor is of a suitable capacitance) and so will be the phase of the magnetomotive forces and hence fluxes created by the windings. Place the two windings mechanically at an angle to one another in the motor and they will create a rotating flux. The radial axis along which the peak flux passes will progress around the stator, first aligning with the capacitor winding then with the non-capacitor winding, repeating for each half-cycle of AC.
Yes. However many windings are in use, either two or three, they should all receive a sinusoidal current where the relative phase angles correspond to the physical angles of displacement of the coils around the stator in electrical degrees (which may be a multiple of the number of mechanical degrees, depending on how many pole-pairs the motor has.) Single-phase capacitor motors typically have two windings not three, in which case the currents might be arranged to differ by 90 electrical degrees i.e. a quarter of a cycle. A 3-phase motor re-purposed to run on single-phase by adding capacitors, should be arranged to receive three peaks 120 electrical degrees apart, as per a normal 3-phase supply.
Although purpose-made motors and generators differ in detail, fundamentally they are identical machines that can serve each other's roles up to a point. What determines whether a machine works as one or the other is where the power is put in (mechanically or electrically) and taken out. Connect a machine to the grid and attach a brake, and it will run as a motor converting electrical power to mechanical. Replace the brake with a Diesel engine and the same machine will run as a generator.
A phase converter has multiple windings and does both at once. The winding energised by the single-phase supply receives power and functions as a motor, turning the rotor. The rotation causes the non-energised windings to function as a generator, from which current (and hence power) is delivered to the load. Part of the load power is converted from electrical to mechanical and back to electrical. The phase relationships of the three output phases are created by the mechanical positions of the windings relative to the rotating flux vector in the converter, just as in a mechanically-driven generator.
That is true as far as real power flow is concerned. There are many subtleties and complexities about phase converters due to the reactive power flows, but you will need some AC circuit theory knowledge to analyse those and the functions of the capacitors in a practical converter setup.
I understand much better now,but do the capacitors in parallel with the none energised windings increase voltage the to same value of the single phase supply (230v) so you get 415v phase to phase at the motor output.
They provide excitation current for the converter. An induction machine driven as a generator won't generate in isolation, because there is no source of excitation power to set up the magnetic flux and hence rotor current. When connected to an AC supply network the machine draws magnetising vars from the network, while delivering in-phase real power watts back to the network.
For an induction generator working as a stand-alone, the magnetising vars can instead come from capacitors connected across the output, which produce a current that leads the stator voltage. For the rotary phase converter the excitation provided by the supply is not equal on all phases, hence an asymmetric arrangement of capacitors is used to compensate for this and provide excitation that gives as near a balanced and correctly-phased output as possible.
Thank you for sharing your knowledge with me.
Reply to Can someone once and forall tell me what a capacitor does in an AC circuit?Thanks. in the UK Electrical Forum area at ElectriciansForums.net
Good morning everyone. I bought some property in northern Michigan and this is on it. Not an electrician, just want to know what it is. I figured...
I have a question about a school circuit called a capacitor in an AC circuit. The capacitor is connected directly to the AC source and the phase...
Evening all, I'm relatively new to the trade and have just moved house. Looking to rewire and was looking at a few things, could someone tell me...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
