Discuss Can you put a150w bulb into a 250w floodlight fitting please? in the Lighting Forum area at ElectriciansForums.net
Different control gear needed for 150w. The physical size of the lamp isn't an issue.
If fitting LED (corn lamp), the existing control gear would have to be disconnected.
As a point, you could use a 250w.
He says it is halogen so it wouldn't need control gear?
Yep.....my boob. :(
Just looking at some old 250w MBFU uplights in a church, today. Buzzing like planes flying over until they warm up. Looking to go LED, corn. It must have been on my mind.:confused:
Just swap 'em then, eh!
YES you can get 150W versions of the j type halogen lamps,
they also make a smaller / shorter one that is 150w.
but in the j size which i think is 111mm yes they are available
maybe not a common size,
So will be harder to find
but a supplier should be able to get them
This will only work on incandesant lamps NOT dis-charge lamps.
if you try it on a discharge lamp ,you will over run it, and destroy it in short order.
Reply to Can you put a150w bulb into a 250w floodlight fitting please? in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
