Discuss Changing consumer unit in the UK Electrical Forum area at ElectriciansForums.net
The DNO here complained the last time I installed 25mm tails in, lol
LOL. NIE have their moments.
They also hate the MET not being in an ISCO outside the DB, and internal copper pipes not being bonded even where the incomer is plastic. I doubt they'll ever change!
Its fairly standard for sparks to uprate the tails to new 25mm ones even if it isn't strictly required...
I don't do many domestics these days , but i always used to stick a tenner on every board change to fit new tails... just something i did
Reply to Changing consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
