Discuss Coding question... in the UK Electrical Forum area at ElectriciansForums.net
Baddegg
Supporter
Patron
Got a consumer unit fitted touching a gas pipe on an upcoming eicr,old rewire-able unit, no idea what came first, unit or pipe, but it’s obviously less than the 150 mm mentioned in the on site guide, I know regs are not retrospective but would that come into it in this instance?.....and how would others code it?
Hi - reading up on this I got :
BS7671 Reg 528.3 - which in this case likely means check for any detrimental impact you can see and code accordingly (as per Tel).
I understand the Gas Man’s BS 6891 is the source of the 150mm minimum between gas and electrical intakes and 25mm between pipes and cables (somewhere, sorry I’ve not got a copy of it).
So if no detrimental impact I’d note it as an observation on your EICR.
Thanks wilko I did wonder why it mentions it in osg but has no blue reg no next to it....makes a change for it to be the plumbers problem doesn’t it ?
Baddegg if it is less than 36 inches it would have to be relocated. NEC article 110 requirements for electrical installations. You asked
Reply to Coding question... in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Would I be correct in thinking an electric cable can be as close as 25mm to a gas meter ? (not that I'd ever be that close out of...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
I was surfing through one of the electrical training groups on Facebook yesterday and came across this question from an AM2 prep course: There...
I'm following a spark who used an existing Panel Heater circuit, for new gas boiler circuit 6 months ago. The panel heaters were removed, so it's...
6K
