Discuss Commercial voltage optimisation in the UK Electrical Forum area at ElectriciansForums.net
Tim
Hi guys,
I am going down this afternoon (3pm) to look at a large supermarket that is having voltage optimisation installed (one of many more on a list) and the electrical firm doing it want to sub it out to company i work for. (The other company and mine have a long standing relationship of passing work across if they get busy)
There is a guy from the other company meeting us there to go through the project and i want to have a list of questions ready to make sure we are all clear on whats going to happen.
I have no experiance in fitting these devices, however i have read a bit about them.
Have any of you fitted these devices and if so did you have any problems? Can anyone see any potencial issues or recommend questions to ask?
All the details i have so far are that its a 'powerperfector' unit, there will be a gennie on site to take over while the unit is installed and it is going to be out of hours.
Thanks in advance for your help,
Tim
First and foremost, you want to see the proposed installation drawings for this installation and the if location is suitably sized and ventilated. If you (your company) need to start doing any initial design work, or there is no installation drawings, you'd be best to walk away....
I am assuming that the design is taken care of by the other company, but i will check. You say the room needs ventilation, do these voltage optimersers give off a significant amount of heat then?
Cheers e54
Tim
They don't work and they cause problems in my experience, mainly discharge lighting...
We've been removing them from service for companies who don't want them anymore. None of the promises were met, they saved no money and it was costing then more in what they had to pay to the company.
We bypassed them, the company who owned them didn't even want them back, said we could keep them.
Of course they do, how much depends on the overall rating of the things and what method they are using to maintain the reduced voltage.
Some also put quite a lot of switching noise on to the supply which can cause other problems with IT and other sensitive equipment that you will then have to solve. I am very wary of large units. Small ones (like UPCs) for computers and critical equipment are fine, but large-scale ones very dubious in my opinion. Better to negotiate a better supply with the DNO rather than try to improve a problematic supply privately on site. I suggest that your firm should be very cautious about accepting this contract job - especially as you have not got experience of such systems.
Alasdair (EMC and power-systems engineer rather than an electrician).
Were the problems with new HF lighting ballests? Ive just done a quick bit of reading while im waiting on site that says they do not benifit from power optimisation and that they have a reduced luminosity due to the lower voltage.
Cheers,
Tim
Cheers,
Tim
It wasnt squire no...standard ballasts...premature lamp failure, and many manufacturers lamps not working in the fittings...
Can't really comment on the HF Flu fitting side of things, but i can see where a supermarket would benefit from a well designed and constructed equipment system. Which would be the multiple refrigeration units, freezer units and store room cold stores, Air Conditioning and ventilation systems etc.
These supermarkets don't run the whole store on voltage optimisation only the larger heavy load equipment, predominantly where motor loads are involved. I can't really see standard ballasts and tubes having premature failures due to 220V, most of those products would be designed/manufactured to be capable of running over a pretty wide voltage range, after all most of Europe is 220 Volt. Manufacturers don't make any stuff purely for the UK market these days!!
OK, you've got me interested now. We've pretty much established that the domestic voltage optimisers are just snake oil, and given that we're not talking about PF correction in this instance....how come it's (maybe) beneficial here?
Reply to Commercial voltage optimisation in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all! I was wondering if there were any electricians here who could share some knowledge please 🙏🏼. I have a Ninja dual zone air fryer...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
