Discuss Compromised/void warranty on panels if original connectors replaced/cut off in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
"And even if they do, what are they likely to do about it?" Panasonic not going to replace them if connectors been replaced that’s what I been told.
Maybe. But how would they know until you've sent the faulty panel back?
It is no point taking that risk as a customer best way just ask Installation company to replace them.
I think that would be unreasonable. For a contractor to do so he would need to buy new panels, erect a scaffold and spend a few hours replacing them. The panels are not going to fail.
My point is that Panasonic's stance is unreasonable. The contractor's actions are neither dangerous nor shoddy and it is unfair to lumber this high expense to a contractor that has performed a perfectly acceptable installation.
Things change in this industry, well almost daily.
When installers were changing connectors it was not a problem, Sanyo were not Panasonic at the time either.
Now this point has been highlighted, maybe the installers who are aware of it will use a different arrangement, spend more money to buy adapters, or just not use Panasonic maybe.
My advice would be, do not worry about it unless you have a problem, there are thousands of panels fitted worldwide that have had connectors changed, if changed correctly they will be fine, if they have not been changed correctly then you chose the wrong installer in the first place.
Try to tell that customer "don’t worry it will be fine" is not very professional. They need to see on black and white that they have warranty. Especially now it had been highlighted with Panasonic they will scrutinize every panel with replaced connectors if they fail. If that’s was you, would want have warranty? I am sure panels are fine but with out warranty.
“Maybe. But how would they know until you've sent the faulty panel back?” You would have to send faulty one back as they require them back under warranty condition. In event that’s they already send replacement then they going to charge for the panel they send you if they found out that’s warranty was compromised “connectors”, is quiet obvious that’s cable will be shorter, even if you replace back to MC3.
I think your creating a problem where none exists, and stiring up things completely unnecessarilly.
Yes, this may be Panasonics stance.
Is that a probem? no.
Is it reasonable or in the customers best interests to bankrupt a company over a problem that doesn't exist? No
If a panel fails, the company will deal with it, otherwise, leave it alone, it's a non issue.
I'm having some difficulty understanding what your trying to do here, although I have my suspicions. This is a non issue.
The customer doesn't have a concern, what we have is, for some reason, a non UK registrant on a UK forum trying to create a concern for UK customers where non exists, nor needs to exist.
Changing the connectors is well within the competence of any UK Solar qualified electrician.
The fact it may be beyond the competence of those in other countries is neither my concern nor my business.
suggesting companies replace entire systems because of a couple of connectors is madness, and if it did happen would bankrupt some installers, although I am having some difficulty understanding the meaning of your paragraph where you quote my sentence on this.
If you don't like the way we do business over here. don't do business over here.
It does not invalidate your BMW warranty if you change the tyres.
added10:13 17.06.12.
interested that you (Valet) have deleted most of the post this response was to, any particular reason?
This concern about replaced connectors not just UK issue I am sure it’s happened in other countries as well. For your info moggy I am UK customer.
And at the point that they decide to charge for the panel, it would be down to the installer. At which point I would loudly tell Panasonic to whistle long and hard out of their backsides.
Ok Valet, just to put the record straight here.
I have never personally cut a connector off of a Sanyo or Panasonic panel.
My post on here was to try and help, nothing more.
Since you feel that my input is unprofessional I will take a bow and leave this stage.
Reply to Compromised/void warranty on panels if original connectors replaced/cut off in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
